It most definitely is in use. It is earthing the back box and the fixing screws.
If you're trying to do the same thing as the OP, you have the same problem - no neutral.
Yes sorry poor choice of words 😂
I assume this kind of switch is not suitable without a rewire
If this 1W switch is wired conventionally, replacing the T&E cable between the light rose and the switch with 3&E will enable you to feed the neutral to the switch.
You might also have a problem with the depth of that back box. Might be wrong, but it looks like 16mm, rather than 25 or 35mm deep.
Yes i hav it at 35mm now but it seems now the wires are the issue i never thought of
How would i go about putting that other N in
The blue wire to the right of your pic (which should have a brown sleeve on it!) is part of the cable which should be the other end of the one in the switch.
Replace this with 3&E, using the grey (with short blue sleeves at each end) for the neutral, the brown replacing the existing brown, and the black (with a short brown sleeve at each end) to replace the existing blue.
Hi. Hope its OK to ask as I have just got the same switch but I need to know which wire goes where as I have a black wire a grey wire and a brown wire which is confusing
