I have recently been asked about some PAT testing work undertaken in a local church hall. The PAT tester did not test the free standing under worktop fridges. The are connected via standard 13 Amp BS1363 plug and socket. The PAT tester said they do not test white goods. I cannot see any logic in this. Does anyone know why this might be?
It’s not really a question of what should and what shouldn’t be tested…. It’s down to the agreement with the customer, if it’s been done through a contract…. You can’t change the agreement without negotiating a new contract
Saying that, white goods should be tested. Although they aren’t “portable” as such.
They can still go faulty, and you don’t want a big lump of metal becoming live!
Link to HSE
Link to HSE
Hello Littlespark, while I agree that you are correct in what you say regarding contract I think most people will look to the PAT tester for guidance on what should be tested. In a situation other than one where the customer specifically stated that white goods were not to be tested I think the PAT tester may need to justify the exclusion of white goods.
I don't see how they can justify it.
All I meant was, that the tester has maybe agreed to do x number of items for y amount of pounds….
Then someone else says comes along and starts testing things that should be tested, but was never agreed to begin with.
They should have been tested from the offset
According to the latest version of ISITEE code of practice, the term PAT is no longer used, as it gives the wrong idea. All electrical equipment, whether portable or not, should be considered for regular inspection and/or testing.
This consideration is to be undertaken as part of a risk assessment conducted by the duty holder, or someone appointed by the duty holder. This risk assessment would normally be done with input from the contractor appointed to do the inspection/testing.
Absolutely. And to be fair it wasn't used in the previous code of practice either. The trouble is most non-electricians don't know the term ISITEE, so we are sort of forced into using the term 'PAT'.
The trouble with 'PAT' is that it often isn't 'portable' equipment, and often it is inspection needed rather than 'test'. Still, the "Appliance' is right 😀
I can see the practical issues of testing stuff that simply cannot be safely moved for access by one person, say washing machine or fridge where the socket & plug are inaccessible behind them.
But they should still be inspected/tested somehow, maybe on a longer period compared to frequently moved stuff more likely to be damaged (hair dryers, extension leads, etc), following a risk assessment and suitable contract with the tester.
If the plugs are accessible then no excuse!
If the item can't reasonably be moved to allow inspection and testing, such as a fully stocked freezer with plug behind, this should be clearly stated as a limitation, you can't just ignore it.
sxdave,
Lucien Nunes,
