- Oct 17, 2011
- 5,313
- 4,858
- 144,758
- France
- Other
- If other, please explain
- Retired Engineer
That is assuming that the molecular structure of copper is not linear, it seems that it is hence its good conductivity, therefore, the compression or tension will be constant along its length of the bend.
