J
John-SJW
You never got my point. RCDs were not required, but were fitted wholescale way before being mandatory, because they were recommended.
There was exceptionally strong reasoning behind the move to RCD protection, whereas the argument in favour of arc fault protection is less compelling. Furthermore, early use of earth leakage protection involved a single device, which involved significantly less relative cost for the end user.You never got my point. RCDs were not required, but were fitted wholescale way before being mandatory, because they were recommended.
As I stated; no suggestion of requirement.
A recommendation is just that and until they become more affordable, it's likely that their adoption will mostly be limited to installations where regs tell us they shall be fitted. Language matters.
I have not looked at page 18 yet. But in normal English shall is not must. Need to get this clear.
Implication | Verbal form | Typical context |
| Requirement | Shall | Normative element |
| Recommendation | Should | Informative element |
It's not as though discussion should be necessary. A quick glance in any dictionary makes clear the meaning of this word.Page 18, in part:
Verbal forms used in BS7671
Implication Verbal form Typical contextRequirement Shall Normative element Recommendation Should Informative element
Yes, like when a judge sentences someone and says “You shall go to prison for 10 years”It's not as though discussion should be necessary. A quick glance in any dictionary makes clear the meaning of this word.
Definition of shall:I'm sorry, but there is no ambiguity where the meaning of shall is concerned
It is a statement 'You shall do this', rather than a question 'shall we do this? '.
The wording clearly states what is to be done and doesn't ask for opinion.
Thanks. Getting clearer. But still some grey here....It's not as though discussion should be necessary. A quick glance in any dictionary makes clear the meaning of this word.
"Shall" is a modal verb used to indicate future action. It is most commonly used in sentences with "I" or "we," and is often found in suggestions, such as "Shall we go?" "Shall" is also frequently used in promises or voluntary actions.
There is a difference between shall and must. If they want to change the definitions of words from dictionaries then they have to state what their words mean. Page 18? If there is an absence of them not supplying a definition for their changed meanings of words, the dictionary meanings are what we go by. Must is well .... must. We all know what that means. No ambiguity. Anything else besides must, does not have to be done.
421.1.7 says: "AFDD"..."shall be provided".
Shall is clearly not must. In short, with must you have to do it. Maybe page 18 clears the air. People need to know if they have to or it is optional.
You shall go to the ball, Cinderella.
