Yes, they said the old fusebox which was made in the 80s, was ineffective. The upgraded fusebox, which says RCD protected, was installed on the basis that it would help with the diagnosis of the fault in the circuit, because the old one was not terribly useful in that regard. The first visit, they did try and identify the fault with the old fusebox, but identified the RCD would assist in this.
What a load of utter nonsense!
Test equipment, knowledge and experience is what is required to find a fault.
An RCD is not used to find faults, it is a protective device designed to make things safe if a fault develops.
