Certificates have not been issued, no.
Im sorry for being dense, the "scope for recompense" can you narrow that? The work was done on 30th November,
Depends how quickly they want their cash moneyWhat time frame do they have to issue the paperwork?
Yes, they said the old fusebox which was made in the 80s, was ineffective. The upgraded fusebox, which says RCD protected, was installed on the basis that it would help with the diagnosis of the fault in the circuit, because the old one was not terribly useful in that regard. The first visit, they did try and identify the fault with the old fusebox, but identified the RCD would assist in this.
Why is the landlord not sorting this out?
Flat, shared, rented, landlord assumptionMy flatmate, went ahead
I remember the first time I watched it been done !That is call a BANG test which is a bit Cowboy
I have worked with plenty sparks over the years who use the BANG test when changing a board overI remember the first time I watched it been done !
Its quite fun really a bit like russian roulette for electricians
