- Nov 30, 2021
- 3,335
- 1
- 2,923
- 3,247,381
- United Kingdom
- Business Name
- Mainline services
You may find the same sort of spark that doesn't fly lead may also not bother with grommets and say It's absolutely fine.I'd also add that chances of a back box becoming live in NI are significantly lower than in GB as there are few circumstances where cable sheath will be in contact with entry point of box. Cables buried in walls are enclosed in conduit and those in stud walls generally enter boxes through a PVC female adaptor that won't easily dislodge like a grommet might.
