I'm not a fan of the rockers on the Click stuff tbh - far too square edged. Makes it feel very 80s.
These are what I've installed back home in China over the 5 years of studying in the UK, and I find British switches truly a piece of wonder! Only a shame that any bigger plates wouldn't fit in my country...
I do find the Varilight dimmer faceplates a bit archaic too (like the Click Polar as you said) but I really like it that way, although still a slight mismatch with the Click Mode switch.
The MK Logic+ such is a serious mismatch with the Bull* emergency switch (in this case used just as a keyed switch to a ceiling lamp). I might replace it with a Schneider Pieno one which comes with a similar profile to the MK.
The Hager Sollysta was intended as just a souvenir but was finally installed to replace my failed MK Logic+.
The Click Polar and the BG Nexus are my souvenirs.
I've recently been interested in Crabtree Capital -
Has anyone been using Crabtree please - and how do they fare?
Quality is good, but Capital has been on the market for years and isn't exactly modern in appearance.
Crabtree have a newer range named instinct which looks much nicer and has an excellent terminal layout, but I haven't used it and can not comment on quality.
Thanks again - I do agree the Capital line looks un-modern!
FWIW, my house had a lot of wiring work undertaken around 15 years ago. It wasn't a total rewire so there are a lot of very legacy faceplates still in use. Around 50% are probably 1990s or older, with the new faceplates being MK Logic Plus for the sockets and MK, Marbo, or Crabtree for other fittings.
Most of the MK Sentry consumer unit was installed around 20 years ago and most of that unit and its modules were retained in the work that took place 15 years ago.
Failures:
buzzing switch on a nearly-new MK Logic Plus 2-way lightswitch after a few months
the plastic broke on the fulcrum of a very old Ashley 2-way lightswitch
a month ago, an MK SP RCBO 30mA type AC that was serving the 1st-floor light circuit since it was installed new 15 years ago tripped and wouldn't stay untripped even with the load disconnected (there was no obvious fault on the circuit and none that I am aware of).
So of the 3 items to require replacement, 2 were modern MK, one was ancient Ashley, and they all related to the lighting circuits. My home installation is more MK than any other brand, but it has struck me as odd that I had two failures with modern MK and none with the older stuff.
Common on dimmers due to the choke used to suppress noise, but on a simple switch a worry!
Either contacts not closing properly, or a loos wire?
It wasn't a loose wire, so either a dodgy contact or plaster dust had got in. I had a broken faceplate that had got dropped before installation and swapped out the switch insert and no problem since then.
