Aug 6, 2022
15
London
Other
If other, please explain
Handyman
We've got a overnight storage heater, fairly old but still going. That was until it starting tripping the RCD, so half the CU went off.
The switch has a crack and upon investigation it was burnt out, melted some of the cable insulation too.
Switch replaced, but radiator still isolated at the CU, I'm not going to turn it on until the new year as I'm slight concerned. Don't want any further hassle over Christmas.
Likely a loose or disconnected neutral, but can it get this bad?
I've seen a few like this and worse. Generally needs a replacement switch and any damaged burnt cable cut off.
Reactions: i3_happy and James
Seen loads, often loose terminals or terminal screw clamping the insulation instead of the copper, or strands not all clamped in the terminal. I usually use bootlace ferrules when connecting flex to things.
London
Other
Handyman
Blown Switch - never had this before!
i3_happy,
freddo,
