Hi, I'm converting my garage into a room, which means the electric meter is being moved outside. With the same move, I want to move the EV charger CU from the garage to outside, as currently the EV charger tails come from the helney block fed by the mains isolator next to the meter. can anyone suggest a suitable EV charger consumner unit that can be placed outdoors, idealy it will go next to the new electric meter box, and this will then feed the EV charging point. thanks
