S
seppe
I currently have an old type rewireable fuse unit & I wish to run power to my garage to supply a light and some sockets. The cables will be run inside the house as the garage is attached but aprox 10m away from fuse board. I’ve had 4 people come and look at the job each have told me a different thing which is right or are they all right? What would you recommend?
- Run a cable from the existing main switch to a new fuse board in the garage.
- I need to have my old fuse board change as it is an old type and that way I would also have a spare fuse to run the new circuit.
- spur off a socket from kitchen in to the garage
- run a cable from an already used fuse to a new fuse board in the garage, but might need to up rate the fuse wire due to the extra load.
