Is it a full PIR or one of those mickey mouse visuals that landlords like? That would be possible but not worth the paper there written on.
I know it's ****, but at the end of the day I'd rather sit on my arse out of work than do these 'drive by' PIR's for anyone.
At least I can sleep safely in my bed knowing that the work I do is to the best of my ability, without cutting corners & with the safety of the people using the installation at the top of the list.
----ers.
I hear what you're saying, mech, and I suppose we could write in the limitations box 'no actual inspection to be carried out' and collect our £25 lol! The problem is that more and more landlords, not understanding or caring what the point of the certificate is, will learn that you can get the bit of paper they need for £25, and every rental house in the country will be potentially dangerous.
The best bit about doing PIRs is all the little 'on the way home' jobs you can pick up from them... bit of bonding here, cracked socket outlet there, easy peasy beer money. You'll also pick up the odd board change and even a few full rewires. There's no way you could afford to identify anything that requires rectification on a twenty five quid inspection, so you just spend your life bored out of your mind for no money. No thanks!
I wonder what would happen if a PIR had so many limitations on it that is was worthlesss and something happened say the house burnt down. Would it be the electrician who did the PIR or the landlord who ordered the work who would be to blame. (limitations should be agreed with the person ordering the work before it commences)
I can see what you are saying but a lot of problems found on a PIR are visual so you may pick up work from them.
Much better to have a decent rate for testing and not have cowboys undercutting everyone. Then a PIR would have real value.
A lot of landlords are only after a return on their investment so want everything done as cheap as possible for the bare minimum to keep things legal.
I can't see any problem with doing a £25 visual check to identify any damages etc as long as the landlords are aware that that is what they're getting.
If everyone sticks together on this it will only be a matter of time before people like that realise if they want a proper PIR they have to pay the proper price for it, the question being whether or not it's right to use the PIR form for a visual check.
Exactly mate, but that's it, we all charge our rates and probably often get laughed off by some agencies and landlords who say 'Terry from behind the bar says he can do it for £25'. Until these Wild Western Wonders are policed out (like that's ever going to happen) the problem is just going to grow.
I don't know about you guys, but I get my PIRs mainly from private landlords who don't have anything to do with letting agencies, and people who are just getting into the letting business. I'll get some repeat business off some of them, sure, but some will either not bother again for 10 years and some will migrate to the 25 quid club. Think about it, we have a forum, what's stopping landlords having a landlords forum, talking to each other and deciding that really all they want is a bit of paper with 'dur lektrik is all orite' written on it, and the work will go to the lowest bidder.
There is no obligation for landlords to get PIRs done, and until there is, there certainly won't be any obligation to get it done properly.
I always thought there was an obligation for landlords to get PIRs done whether it be the law, insurer's requirements etc, hence being the only reason they bother at all - after all, £25 for a worthless bit of paper is £25 too expensive whichever way you look at it.
Sadly, it isn't law. The push is through what is effectively no more than Health and Safety - and in essence, the only requirement is to "prove" that you did the minimum necessary to provide a safe system.
It should be law, however, and IMO, we don't really have any better LEGAL responsibility than Victorian landlords did for their slums.
The other problem, of course, is that any "clever" landlord will spend years and masses of tenant money fighting any claim that he was negligent in any way - way too many loop holes still.
In new builds, the builder is obliged to produce an EIC for the electrical work as part of the handover package - but that still isn't law. It's pressure from insurers, bankers, and NHBC type schemes to ensure there is no come back on them in any way that will affect their income.
The fundamental problem is, and remains, that money remains the issue, and nobody up the chain actually gives a **** about safety, only so long as it doesn't stop their income.
IMO, it would be a simple matter to resolve almost all of the problems in one fairly clear law - which might be entitled "The Electrical Installations" Act.
It would prescribe minimums for each stage of any installation, and the maintenance thereof, from the point of connection to the DNO supply onward, until point of termination at any fixed appliance, accessory, or other device which can reasonably be considered a termination. It would in ALL respects be the law applied to all such matters.
For example - it would MANDATE the provision of a SAFE isolation point AFTER the metred DNO supply, and BEFORE the primary consumer unit, or distribution board, and would in ALL cases safely isolate the ENTIRE supply into the building. E.g. that would be a three phase isolator if more than one phase was supplied. I can think of NO CASE AT ALL where isolating one out of three phases in a building can be considered safe isolation of the supply into the building, by the way.
From this point on, of necessity, it would call much of BS7671 into law also.
Critically, it would mandate a minimum qualification and licencing for working on any system, a method of recording irrevocably any work or tampering of the system (which isn't that hard to implement), and a minimum testing and inspection schedule - which IMO should be three yearly in a typical domestic, annually in commercial, and after any change in the installation, as minimums.
Why three years? Quite simply, with the pace of technology today, consumption of domestic households is NOT reducing - it is still INCREASING marginally, year on year. In three years from 2007 to 2010, the increase in electrical gadgetry in homes increased to such a point that a 60A main supply is not enough in over 70% of homes now. And 80A supplies are also reaching their limits fast.
Most DNO's are facing the fact now that even 100A supplies will not be sufficient before too many more years pass, and are wondering with quavering rear pipes whether or not they are looking at substantial grid rewiring - upto and including the final concentric into buildings.
We all know that a 100A HNVC fuse will supply well over 100A before it blows. And we all know too that if domestic circuits start getting overloaded, people are all too willing to simply run extension leads from other circuits, rather than have the fault fixed. - This is another tale altogether, and one in which we get into discussions of whether ring finals or radials are better.....
Either way, I think the time has come that we have a large number of fairly critical issues affecting the industry, some of which ,granted, have been with us for years, but it is time for our esteemed "industry bodies" to get off their rears, and start making noise on our behalf at all levels.
Or am I missing the plot somewhere?
Benny_Boy,
accordfire,
