There's only one easy way to chop out engineering bricks, and it involves artilliery.......
For me it depends on the property and location/use. if the house is empty then ill chase out with a angle grinder/wall chaser cos chances are the place is gonna be a mess anyway with other work going on, just remember to where a decent mask and goggles. Also its easier to fill if the customer wants it filling in by you.
If its in an occuppied house use scutch/chisels cos much less mess and they will expect you to get the thick up at least. But do get a decent SDS with rotor stop so much quicker. When it comes to Engineering bricks the better the drill n chisel/bit the quicker it will be. Scutches are good cos you can change the blades when they are worn out.
Otherwise get a labourer. LOL
Lol!!! Since when have screwfix started stocking shape charges??
Or were you thinking more along the lines of just hit it with a RPG and let the plasterers sort the rest
Last mansion project I was on the builders hired a guy just for chasing and hole boring, he made as much as I do on a good day every day of the week!
Seen that before. Plan was made up and the guy drilled and cut out everything needed. then "pullers" did the cables . It can really work when one man is set up to do a specific job
I completely agree, on really big jobs its by far the best way to go. I used to work for the council and we had to re wire entire houses in one day, 6 men, 2 chasing and box drilling, 2 men power, 2 men lights. first fix, done in usally 3-4 hours, then second fix on the afternoon, 1 man on CU and testing and then 1man 1 room then move on. very quick.
I can get hold of a few of these, might just do the job
scutch chisel (its more accurate and gives neater edges than a cold or bolster chisel), lump hammer, gloves (to stop blisters). its better to get a drill with rotary stop, and use a chisel buit on it, but always have hammer and cold/bolster/scutch handy in case of no power ect.
Yep and nice neat stitch drilling.
