P
Phil
Round and round and round and round and round we go
where will the neutral stop ? no body knows
I reckon it'll stop in the middle - seems like a neutral area.
Then we can resurrect this discussion in a couple of months after we've done exporting earths to outbuildings, what the different colours of 3 core cable should be used for, and time served vs fast track again.
I certainly hope it's finished ...lol!!!
Why?? Because that is my honest opinion of this wiring method, so why would i change my opinion, certainly not going to change it based on what's been written here... And as i said, i'm not going to change your opinion, that this is a good wiring method, ...end of as far as i'm concerned!!!
It seems the only benefit of always looping the live at the light is that certain older electricians understand it because they're used to it.
Engineer, you can easily change my opinion. Just explain what's wrong with looping at the switch without using the words 'bad practice'
You are right, 3 plating is a good wiring system, but so too is using the switch box.
Whats the difference between taking all your cables to an enclosure in the ceiling or on the ceiling and running one cable to the switch, and taking all your cables to the switch and running one cable to the light. Please note, I've asked what the difference is and not whether it's good practice.
