Discuss Swa cutter in the Electrical Tools and Products area at ElectriciansForums.net
J
James Sutton
Hello All
Got myself one of those Armoured strippers looks abit like a pipe cutter takes the armour of up ta 10mm 16mm needs abit of help from the trusty hacksaw but does save alot of time. Just wanted to know if there was one that can be used for bigger cables as it does speed things up abit when terminating swa etc
JS
About a year ago they were asking for £100 for the SACS, so it has come down. Personally I'd have one at £50, but i am considering it now at £70 because I've had 3 of those cheap Kewtech jobbies and all have broken after relatively little use. The SACS looks like it will last a lifetime.
Hello All
JS
Hi James
How big a cable do you want the tool to operate on??
How much was that there armour saw then???
Errrmm £60, overpriced but it works great. The only reason I can see as to why they are so expensive is that ITL supply tools to local DNO who probably don't care how much they pay as long as it comes with a kite mark or BS number.
Do you know what, I'm getting the biggest feeling of deja vu here....I'm sure we've had this conversation before.......
Fancy one of those SACS tool,bit pricey though.Is it all metal construction ?
Those yellow Kewtech ones are rubbish currently using hacksaw and getting quicker.
KewTech do a large one aswell, the small ones are okay, saves time and gives a perfect cut, just dont buy the proper spare blades for them as they cost an arm and a leg! just get a pack of junior hacksaw blades, cut one down to size and you can replace the blade in the kewtech tool.
I'd buy one if they offered a refund based on that if its no good. Seen too many of these things for sale and they are all bobbins
To be honest I would rather just use a junior hacksaw (small cables) or a 12" hacksaw for the larger cables. For stripping the armour and inner then two stanley knives are my preferred tools. One for stripping the outer sheath, and one with a brand new razor sharp blade for stripping the inner sheath off.
I have tried to use numerous types of stripping tools (Shell banne dthe use of Knives offshore approx 2000), but none even come close to being as good as a stanley knife for stripping.
Have I mentioned at all that a friend of mine invented the blade runner that Kewtech now sell?
When I first started making armoured cables off about 15/16 years ago I used to think how come there isn't a tool for the cutting of outer sheath/armour in one uniform depth, and that after all, a simple design closely resembling an adjustable copper pipe cutter with a sturdier blade than the cutting disc of said pipe cutter would do the trick. Lo and behold how many years later when the blade runner came out I did give myself the proverbial kick and wondered if someone had been stealing my thoughts!
Ive never used or even held a blade runner in the flesh though now, I am interested in one of those armour saw's if anyone has a link to UK stockists ?
Grats to your friend, hope he is doing well enough from the patent/rights/royalties ?
I knew he was doing the deal with someone long before it was on the shelves. I should point out that 'he' isn't exactly my friend, it would be more truthful to say his son is my friend and lives just down the road from me. To be honest I'm not sure how well he did, not that well I don't think and I know shortly after doing the deal he met with ill health. He had been featured in Professional Electrician magazine with his invention which at that time was a modified pipe cutter. I got in contact with him through that because I hadn't seen him for many years (he was estranged from his son). I managed to get his telephone number off his van in the photograph lol. Was good because of all that, I put him back into contact with his son :)
I use a ratcheting pipe cutter, cost about a tenner from Wickes i think. Don't do much SWA work, but it is OK for cables with an OD of about 25mm. Nice clean cut in insulation and good score into armouring which lets it snap easy enough. Probably wouldnt last too long if you were doing it all day everyday, but for the odd occasions i use it, its good enough for me. Its also good on SY as well.
Cheers...........Howard
i like the idea of that armour saw, i got marked down in practicle exam becasue i was really tired and for some reason decided to cut all the way through instead of just the armouring
(i think i was in automode becasue i had very little sleep)
to give you an idea, i was like this in morning break just before it happend
Since this thread last had an airing I had another go with the Kewtec cutter. After a couple of failed attempts I had a close look at the blade and noticed the teeth were the wrong way round.
I pulled the blade out of the plastic disc with a pair of pliers and lo, it's just a 20mm length of Junior hacksaw blade wedged in to the holder. I imagine that the official replacement blades are £££. I just reversed the blade and pushed it back into the plastic slot and it works fine on cable sizes up to 25mm4c
@BlueToBits
I found this as well with mine, as the blade was running backwards and not scoring the steel wire that much. I turned the blade around in the holder like you said and now it seems to work better.
Reply to Swa cutter in the Electrical Tools and Products area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Some friends are setting up a metal workshop inside a shipping container, on site at a commercial building that rents out studios, workshop space...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Just taken deilvery of an Electric Car (Mini Electric) and so doing some research into installing a charge point. Supply is a standard Single...
4K
