J
James Sutton
Hello All
Got myself one of those Armoured strippers looks abit like a pipe cutter takes the armour of up ta 10mm 16mm needs abit of help from the trusty hacksaw but does save alot of time. Just wanted to know if there was one that can be used for bigger cables as it does speed things up abit when terminating swa etc
JS
I fancied one of the SACS tool but it has been priced too high for the occasional SWA user. Looks really good though.
About a year ago they were asking for £100 for the SACS, so it has come down. Personally I'd have one at £50, but i am considering it now at £70 because I've had 3 of those cheap Kewtech jobbies and all have broken after relatively little use. The SACS looks like it will last a lifetime.
Hello All
JS
Hi James
How big a cable do you want the tool to operate on??
cant beat junior hacksaw for boootlaces, and normal hackswa for bigger ones. my tip is if you wana make sure your line is straight on larger sizes, use a cable tie to guide your hacksaw.
agree with insulation tape! might give the cable tie idea ago next one I make off.
Sent from my HTC Desire using Tapatalk
How much was that there armour saw then???
Errrmm £60, overpriced but it works great. The only reason I can see as to why they are so expensive is that ITL supply tools to local DNO who probably don't care how much they pay as long as it comes with a kite mark or BS number.
Do you know what, I'm getting the biggest feeling of deja vu here....I'm sure we've had this conversation before.......
James Sutton,
stitch,
