Discuss LED GU10 lamps in the Electrical Tools and Products area at ElectriciansForums.net
keniff
hi guys and gals, just finished putting downlights throughout my living room, looking for some led gu10's anyone recommend any? i want ice white really and cant find any bargains wondered if anyone knew of some?
Diamond LED 3watt cool white £8+vat each. available from Electric Center. or look at Haler.
Cheers guys I'll look into these, I'm hoping for a bright clean White look so these seem the way forward
i fitted 6 of the 3watt cool white in our kitchen- really bright. one failed after 3 months so took it back and got free replacement no problem.
Just spoke to electric centre they can't find them on their system, anyone got the product code? Also do they fit flush in standard gu10 fitting?
Reply to LED GU10 lamps in the Electrical Tools and Products area at ElectriciansForums.net
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hello All Living room will have 12 GU10s. Can anyone recommend any dimmable bulbs that won't flicker and be around 400 lumens each? I've got 4 in...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
