Discuss which way around for the generation meter??? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
E
erf151an001
Sorry if this is a stupid question. Does the AC from the inverter connect to the load side of the meter or the supply side? I assume to measure the output of the panels it connects to the load side??
Apologies if this has been answered before/ stupid question
Regards
Erf
thanks
yes the generation meter. For some reason couldnt get my head around it!
So to clear it up, the output from the inverter i.e. the output from the panels connects into the supply side nof the generation meter then the load connection into the dedicated mcb in the consumer unit?
Pretty much , not forgetting your appropriate isolation of course .
I am sorry to cut in on this are you certain that the inverter feeds the supply side and not the load , im sure ive read somewhere that the pv is always classed as load . any experts please clarify possibly with line diagram . Cheers
Jeff, the meter is there to measure the output of the inverter so the inverter has to be connected to the supply side. From left to right: inverter line, inverter neutral, neutral to consumer unit, line to consumer unit.
Definitely the correct information given here.
I know this as ours was wired up the wrong way round!!!
I contacted the installers after the 1st day when the meter reading hadn't changed and he suggested this would explain it. They came out straight away and corrected it but were amazed that their electrician had got it wrong as he's done many for them previously.
I guess it's just second nature for an electrician to think of the consumer unit as the supply side.
Reply to which way around for the generation meter??? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
I currently have a 3Kwh solar PV system which was installed over 12 years ago and getting a very good FIT payment and I don't want to lose it! I'm...
4K
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
