Hi, no I mean the white panel with the double socket, what looks like an isolator and two samples of cable on it.
Looks like some kind of temporary supply to me.
As Ad says a temp board, or my money may be on a proving rig for doing self calibration of your instruments, with the two pieces of 10mm and 16mm for resistance and the RCD for a reference unit or it just doubles up as both.
you will find this is a temp cu for power while doing rewires ect for using chargers ect ??
That's exactly what it is...Plug it into the meter and away you go. Used mainly for boiling the kettle though!!!
The two short lengths (was three) of CPC at the bottom are / were 6mm 10mm and 16mm. If ever I come across an earth and not sure what size it is, I measure it against them. Sometimes a bonding / earthing cable on it's own can be difficult to identify if you don't have anything to reference it with.
Think i might have to take a few pics of the new van since my last one received so many positive reviews! :)
Watch this space!
Hi, if anyone suspends a ladder inside the van from the roof I'd be really grateful for a few close ups of the bracket arrangement, in particular how it's attached to the roof frame. Might save a bit of time thinking about it. Thanks loads, SW.
I mind finding something American by accident and found a bracket thingy to fit to uni inside van clipped and clamped steps looked the buisness Other than that If used fishplated screwed rod and uni in old van with a bit of AC pipe imnsullation on uni to stop the squeeking
tha's my currently configuration in an opel combo C
