Currently reading:
D.I.Y. REWIRE-- A Step By Step Guide.
Discuss D.I.Y. REWIRE-- A Step By Step Guide. in the Australia area at ElectriciansForums.net
telectrix
Mentor
1. Remove all heavy furniture from upstairs. Place in Storage.
2. Roll up all upstairs carpets. Ditto.
3. Lift floorboards to enable cable routing (not the ones that the plumber has wrecked, fitting central heating)
4. Move all downstairs furniture to centre of rooms and cover with dust sheets.
5. Cover all ground floor carpets with polythene sheeting.
6. Chase out from ground floor ceiling vertically to every point you require a fitting/accessory.
7. Now that you've realised that you are totally out of your depth, get on the phone to a qualified Sparks.
Although I do agree with all the other electricians on this thread to "get an electrician", as I do think you will certainly be out your depth at some point through your DIY project (and is it really worth taking the risk of your home with your family in?)
I do admire your interest to even join this forum and further your knowledge, and you seem to have done your research on the basics.
Even though there will be errors made you do seem to have made more effort than most DIYers.
It was just the picture of a bloke with steinels as a stephescope that got me jb. Had me thinking it was aimed at diyers so i had visions of people poking around with those pound shop neon screwdrivers which i think are damn right dangerous and should be banned. i bought some insulated screwdrivers a while back with one of those things thrown in and it went straight in the bin.......
Although I do agree with all the other electricians on this thread to "get an electrician".
ruston said:
Spot on and good luck. Whatever you do though get it checked out. You can understand the reluctance of people not wanting to give advice on the heading of your post though . General questions may have yielded better replies if your level of understanding had been more prevalent.
Worth noting, if these are aimed at me, that I was not the OP of this thread ... the thread itself was started by an electrician, I just joined a bit of lively debate.. I wouldn't start a thread by asking for a step-by-step guide to rewiring... I would agree that anyone doing so (if asking for advice that way) is probably out of their depth and even I would be the amongst the first to say "call an electrician"
It's also worth noting that whilst I will happily undertake electrical work in my own house, and do minor things for family members like change a light fitting or connect a new appliance etc - I'd never undertake any major electrical work in anyone else's home.. I'd always advise they call an electrician and there's a few who I'll happily recommend who I've dealt with before :)
Sorry to be short and blunt rsmck but I don't agree with what your doing, without formal and proper training (not books) I don't agree with you rewiring your house or anybody else for that matter, its wrong and dangerous and should be outlawed IMHO, Electricians don't sit maybe 15 separate exams over 4-5 years sometimes spending £1000's in course fee's and maybe an Apprenticeship and another £500 on a part p competent persons scheme for nothing you know, annoys me that somebody who can buy a £60 bs7671 and a book of amazon thinks they can rewire a house CORRECTLY
rsmck you seem to be a sound bloke, giving good replys and not having an attitude as most would on forums, this is what makes this forum different to others I think, which is why I've been a member of this forum longer than any other and check in on here daily.
The important thing is not to get your intentions mixed up with your capabilities, and I'm sure your not...
Noted.
It depends on the electrician I guess, but there's a lot out there that have undertaken much shorter courses and still advertise themselves as electricians. Obviously the Part P scheme is a bit of a moot point in my case..
I appreciate there's things learned by experience - same is true of everything - but I've always been a believer that formal training, whilst beneficial, is not a pre-requisite and that you can teach yourself most things if you need to (look at what they did with the ATA's Ferry Pilot's Notes from WWII if you want an extreme example ;))
Everyone has their own interpretation of "correctly", there is more than one way to rewire a house. I am not claiming I am rewiring my home exactly as you would nor that your own experience and training most likely would lead you to do some things differently. But rather that it is done safely and, as far as reasonably practicable, in compliance with the 17th Edition of BS7671 which is good enough for me :)
rsmck you seem to be a sound bloke, giving good replys and not having an attitude as most would on forums.
Thankyou :)
I'll do my best not to. If I am ever unsure (about anything) then I will ask someone - either via forums such as this or via some professionals I know personally (sadly none of which live locally!).
If I don't understand the REASON behind the answer, I won't do it. I will never just blindly follow instructions. When I reach the point that I don't understand why something is done a particular way, or why a particular regulation is what it is, then I would employ a professional.
This applies to everything, not just electrical work. I also accept my small house is very different from much larger projects that you're all trained to work with - your training will cover a lot more than what I need for this particular purpose.
p.s. my real work (both my full time job and a completely different hobby that's rapidly became a part-time job) involves a good understanding of electricity - so I'm not completely 'new' to the concepts :)
Agreed
Take heed.
WHEN you get out of your depth, you may not find a sparks and if you do I hope they are very expensive
I do appreciate the risks involved this is why, even as a DIYer, I've spent some time studying the regs alongside the ECA's "Guide to the Wiring Regulations" and conducting the relevant tests (and recording the results)
Conducting the relevant tests - Once the install is completed i assume you are going to get it inspected & tested by a competent spark - as i'm sure your aware the test equipment required (to measure Zs and Pfc for example) is not cheap. A multifunction tester costs at least 500 notes....
I think my Fluke 1653B will be suitable, it's certainly helped so far :)
Just wondering if rmsck was thinking about joining our trade (properly)?
The thought had crossed my mind in the past... although for a variety of reasons the more physical bits (crawling about roof / floor voids etc) would become quite tricky through time as I have occasional problems with my back (old injury).. my desk-based job is probably more sensible :(
That said I spend a lot of time, when not working, clambering about, working at height and moving heavy stuff about in just the way my doc advised I probably shouldn't ... unfortunately I'd miss it too much.
Another one using these popular multi function contraptions
Aim for quality and get yourself some decent individual instruments
If I was an electrician... I probably would. I do have a single Kewtech Earth Loop tester that I inherited from someone else... oh and a Megger PAT tester inflicted on me by a former employer... that said it's not too useful for installations and I've no inclination whatsoever to start PAT testing appliances at home ;)
Its all the little things that need to be thought of.
I'll give one example which is where does it specifically say to put grommets in the knockouts of the back boxes?
I guarantee you an electrician would be able to pick out a dangerous mistake that has occurred from your installation.
How do you sleep at night.... Can see you on the next horlicks advert.
Look mate, sorry to burst your bubble but 99% of DIY sparkies ain't got a scoobie what they're doing. Its as simple as that. Sure they may be able to follow a nice wiring diagram but they won't have a clue when it comes to testing, safe zones for a bathroom, cable calcs etc etc. So whilst you may be able to convince your missus that you are saving a few quid - you are mugging yourself off at the same time. If DIY electrics was such an easy thing then it wouldn't be banned in most countries. However enjoy your DIY electrics whilst you can, because it will be banned here soon as well. Part P - Do you know what this is by the way? Is the first step to stopping Mr DIYer.
Sorry mate, but amateur electrics kill.
Sorry mate, but I have to disagree with a lot of that.
Firstly you're talking about "DIY sparkies", well there are a lot out there. There are idiots who couldn't fit a lighting pendant, and people like myself and rsmck, who aren't electricians by trade but are still competent.
I've not yet got my C&G (although they're well in the pipeline), but I've spent countless hours studying the regs. I've got copies of the OSG, Building Regs for Electricians as well as the Holy Bible 7671, all of which I've read inside out. If I don't know something, I look it up. From the tone of his posts, rsmck is similar.
If someone is on here asking for advice, I think it's pretty reasonable to expect that they're not a complete amateur, or "know it all" DIYer. People come here for advice because they want to do things right.
As for "amateur electrics kill", I think what you mean is "amateur electrics have the potential to kill". Seriously, how many stories do you read in the paper about people being electrocuted? My other half is an A+E doctor and has been for several years. She's yet to see someone in for treatment following a domestic electrics incident.
Well that's common sense - when running a cable through something with sharp metal edges. - but in any event as far as I know not a legal requirement (the NICEIC confirm it's not a deficiency in it's own right but the cable sheath must be 'adequately protected from damage')
But in any event.. I would always use them.
I am confident they wouldn't find anything dangerous. There are a few things that aren't quite perfect ( data cables ran near mains, sockets at wrong height (due to pre-existing positions) etc due to limitations of the building.
There is also one small ceiling which has cables above it which have been pulled through that aren't clipped yet, however that will be remedied as soon as the bathroom above it is renovated. I still maintain my new (albeit unclipped) 1.5mm T&E that's properly terminated is safer than the previous VIR rubber cable with the insulation flaking off it that got ripped out ;)
Very well.
Agreed 100% - loads of things have the potential to kill. I have a friend who's a paramedic and has attended many 100s of road traffic collisions and industrial accidents where there have been fatalities. He's yet to attend where the patient has suffered any form of serious electric shock (he did once attend a DIYer who tried to change a light fitting without isolating it, to treat him for the leg injuries sustained when he fell off the ladder!)
I'm also on good terms with our local fire service - I asked someone a while ago about common causes of fires they attend and "botched electrics" is very rare - old and poorly maintained electrics being far more common but more often than not - kitchen fires, cigarettes, matches, candles...
So yes, amateur electrics (like many things) have the potential to kill but so do cars, cookers, ladders ... All of which are safe and useful tools if used safely.
i dont know why you joined this forum rsmck u seem to know everything allready.
maybe i should re-phrase that *think you know everything*
Constructive, thankyou.
I do not claim to know everything, nor do I believe I have ever implied I do. I do find it somewhat amusing that having joined this forum over a year ago your only contribution has to been to attempt to belittle another forum member (badly)
As you yourself have said, this forum is a useful resource, and there have been a lot of very helpful members on here for which I am very grateful of the assistance and advice they have given.
fair play to rsmck, seems to have a good attitude and approach to his rewire. if LABC have been notified and will be inspecting the job, then nobody on this forum can fault for that, as that way, he would be complying with all regulations.
Thanks, I try.. if I knew everything I wouldn't be here :)
LABC have been notified (I asked about it at the same time as applying to remove a wall) but have no interest at all as it falls outwith the scope of work which requires a building warrant. Ironically, it would only require a building warrant if I was adding recessed sockets to a party wall!
I had previously rewired my flat - that did need a building warrant and subsequent inspection by LABC.
For the benefit of those south of the border - the following guide produced by SBSA shows what work does/does not require a warrant under the Building (Scotland) Regulations 2004 -
http://www.angus.gov.uk/buildingcontrol/electricalmatrix.pdf
It's very different from your Part P, for now anyway.
sorry, i forgot you were in scotland. obviously part pee does not apply. i have no idea of the building regs. in scotland , so cannot comment further in that respect.
rmsck
i have just finished college Got my C&G 2330 level 3 am 17th edition qualified as well as a nVQ level 2. Ive been studying full time for 2 years.
One thing this studying has taught me is that there is so much to it. I am not a sparkie yet i still have a long way to go.
Yes i could run the cables, Wire it up and get everything to work, thats the easy bit.
But would i be 100% confident in my installation. Enough to sleep soundly at night whilst my 4 year old son is in the next room.
Would i wonder if all the tests i carried out had the right readings, would i be confident in the readings i wrote down, If any of the readings were slightly high would i know the reason why or would i be gambling.
After 2 years i wouldnt risk it i have have studied enough to know the dangers, ask the guys they know there stuff, i do.
cheers
Reply to D.I.Y. REWIRE-- A Step By Step Guide. in the Australia area at ElectriciansForums.net
