Discuss bosch GOP 10.8v in the Electrical Tools and Products area at ElectriciansForums.net
K
Kiers1970
Got me out of a right pickle last night, great handy tool. last week had to cut the back out of a cut outs mounting board, saved me then too as all the cables for the house were behind the board, had to cut it because they werent long enough for the new consumer unit (or mains board as I'm constantly annoyed hearing people saying....)
On that note, don't you hate it when people call tools by the wrong name.. a fella I had working for me constantly called Grips Dogs.... maybe I'm getting old!
I never go to a job with out mine (only have the cheap 230v version) but it works all the same unless theres no power.
I will be saving up for the 10.8 cordless one soon.
Ive got the 10.8v GOP too, a great little too for cutting plaster board boxes out.
I too use it for cutting out dry wall boxes, so much neater than the pad saw.
When I got it I was not sure how much I would use it but now I would not be without it.
Same here, this weekends tool show will be replacing the blades I have seriously hammered over the last few weeks!
The price of the blades is the only draw back for me B&Q were doing a deal about a year ago buy 3 or more and get 50% off I am keeping am eye out incase the offer comes up again.
Hadn't seen this thread, but bought one today for using to chop dryline boxes. Have christened it by using it to sand down a table at home but look forward to using it on site properly. Seems a brilliant bit of kit so far.
I bought a GOP10.8V, and aside from being a handy tools to cut plasterboard boxes out, and the odd sanding job, it's had very little use.
I'm still after a half decent tool for cutting the ali rails on suspended ceilings for trunking drops - anyone have any suggestions?
That just prompted me to take mine to bits and have a look at it. In the head there's an offset cam driven by the motor, the connection between the motor section and offset cam is via an hex "nylon" bush driven from the hex head on the motor end. Nothing too expensive to fix it. I say nylon, not sure what the material is as it's embedded in the head.
I use the GOP for the ceiling rail chopping. Works a treat.
A cracking bit of kit.
I take it you had a "day at races" then? :)
Yep, with exception of a larger sized Bosch L-Boxx, I only bought what I went there for.
Oh, Elliotts tools in Fratton are having a sale on all this week.
U use a pair of Gilbows, if it is round conduit, then a faint pencil mark on the edging either side of the conduit, then snip the edging with the Gilbows angled into the cut out section. As long as you always keep the top blade resting on the section you do not want removed so the bottom blade cuts up the edging on the part to be removed, you should always leave the edging looking good.
Cheers, so basically big-assed version of a tin-snip then :) I only need to do it occasionally, and it's normally for flat trunking as it's for data installs. Still, there's a part of me that says that if the job can be done with a power tool, then that is the right and the proper way to do it. My experiments with a angle grinder were not hugely safe, and required patching the wall ;)
The fein is £600 had a play with one last week and its an amazing piece of kit. Would love one but it's £600 (or £500 without blades)
Will probably get the 110 version for now
£600 :rolleyes4: That's insane. Don't quite see how they can justify that.
The only way 'er indoors' would let me buy that is if it doubled as a vibrator :rofl:
I got talking to one of my local tool suppliers at the Elexshow today, when chatting he said they now stock Imperial Multicutter blades that are harder wearing and a lot cheaper about £20 + VAT for £ BI Metal cutters.
He then told me to check out youtube for them, going by this youtube clip they cant be bad!
I will get some tomorrow or next week to give them a try.
used it today to zip through Kingspan, what a breeze, BUT a tiny piece of the foil somehow got lodged in between my teeth!!! felt like i was sucking on a PP9!!
Reply to bosch GOP 10.8v in the Electrical Tools and Products area at ElectriciansForums.net
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, My son has just (last week) had a rewire done on his house in Leyland. He has just bought the house but a "domino" type consumer unit was...
12K
Hello. Wondering if someone could give me some advice on my Veritas alarm. I recently had an extended power cut, when the power was...
