Marvo's right about making sure that there's a route for allowing air into the room. I cut the bottom off the door, making sure that there's at least half an inch gap.
I tend to go for a high pressure fan of 160 or even 250 cu m /h. The ordinary cheap in-line fans are OK for trickle ventilation but can't really cope with the amount of water vapour produced by a good hot shower. Also make sure that any flexible ducting is as straight as possible with any corrugations pulled out flat. If necessary cut the ducting shorter and pull.
a cheap fan kit will only pull upto three meters in length. a vent axia or other quality make will pull much further,but no fan will stop the room steaming up only make it steam up less. if your fan can hold a single piece of toilet paper then thats it working. you get what you pay for
...no fan will stop the room steaming up only make it steam up less.
A few years ago I added a 250 cu m /h fan to my own shower room, pulling air from immediately above the shower cubicle, and provided an air inlet to the room. Since then neither of the mirrors in the room steam up. Mind you, there's quite a draught under the door!
The fan is triggered by a flow switch in the pipe feeding the pumped shower head and runs on for a few minutes.
got an inline in my shower room at home and its a load of crap.......will sling it and get a better one.....it`t a manrose by the way....cheap contract crappiness..lol...........
Extracting from directly above the shower would be the best way to go.Obviously you get a lot of condensation through the system so I would make the run-on period as long as 10 minutes if you can to dry it out fully after a shower.
ianphilip007,
Marvo,
