Good morning all and sundry,
Went to have a look at a small job the other day where a Gas fitter had fitted a new boiler and a BS1363 plug to temporarily fire it up and wanted me to replace the plug with a SFCU. I said Ok I'll have a look.
Now, when I got on site, I took one look at the condition of the kitchen wiring and made a decision that the electrical wiring required a PIR. I then asked to have a look at the CCU and was told that it was unavailable because her husband was ill in bed.... Fine I thought, no problem. call me back when I can get access.
So the boiler's electrical supply is connected via a switched plug and socket, and as far as I'm concerned that is Ok because it provides both isolation and overcurrent/fault protection. However, the gas fitter states that the Gas regulations require the boiler to be hard wired, I disagree.
What's your thoughts on the matter?
