It was a like-to-like replacement and I even used the same holes on the wall. I explained to them that these lamps have heat sensitve sensors and the hot flu from the boiler was the culprit. The inmates moved in a month ago and that light never worked since, hence they wouldn't know there was an issue.I don't have any other suggestions than to relocate. They're sensitive to heat variations so any heat source in their viewline will play havoc.
