I can save them on this macbook, maybe it is because I have adobe acrobat on it which is the default for any PDF file on all my computers, what adobe version do you have?
Just managed to edit and save on my ipad aswell.
I did not change any of the security settings so you should be able to carry on as before.
Hi Mark
Do we have an updated version of this PDF to match the NICEIC format ones? , the NIC one has the tick boxes laid out different , or is there a way of editing the pdf to change it round to match the NIC version?
Thanks mate
Andy
Ah ok. Thanks for that.
Does anyone know if how we can make changes to these forms? Ive tried to delete bits to make it similar to the NICEIC one but it wot allow it. How did Mark access it to change it?
I can do a full edit, but to copy the NIC, PIRform or Tysoft versions like for like, would end up in too much aggro with some copyright problems.
Hi Mark,
have you paid for a serious piece of picture / document software then?
I have an ad done by a graphic designer, he can edit it and it's a .pdf. Dunno what he uses though. What do you use?
Spartykus
We have been updating our certs and have created the new EICR that will come with the next amendment. You can insert your own logo and the signature fields also take an image if you need to email them to your customer. You will be prompted for the report number. Please RTFM!!!!! All the usual bits, no warranty, liability etc, just enjoy!:D
Perhaps admin can make this a sticky?
Steve.
Steve,
i seem to be having a few problems down loaded your pdfs great but they do not function because i dont have 8.1 adobe. the link in the warning box that pops up does not work and when ive tried to manualy find it it does not down load?!?
all of this aside thinking its my pc. are these forms avalible in another editable format?
Cheers for all the hard work. much appreciated.
Mike
Steve,
Mike
Hi Mike,
These are the slightly amended versions of which other forum members have spotted errors and have been corrected.
You should be able to open them in that version of adobe, maybe you have a setting on your version that needs amending?
Mark.
Single board, page 3 of 9, M.observations, what is the yes/no drop down box/list for, is it for answering if any remedial action is required or if further investigation is required ?
Paul.
Could I please ask for help with the EICR forms, hope you don't mind. How do you input your own logo the field seems to be protected unless I am doing it wrong. Hope someone could please assist. The forms are great.
I just click on the logo field, then a window opens, navigate to wherever your logo is on your pc.
Paul.
Hi Paul, thank you for your reply, I tried that and the applet just turns red I do not get another window. I am using windows XP, adobe reader X and java script is enabled. When I open the forms I do get a message saying 'the PDF file needs a newer version of adobe reader, any ideas, many thanks again.
Go HERE and select what it says to get the latest available version for your PC.
Tester Steve,
mydigitalhome,
