N
new2this
Hi all,
Right i just need my workings checked before i do anythng.
I have a shed that needs power. Its roughly 10m away.
Im using a 40 A MCB in the house CU and running 6mm SWA from there to a second CU in shed which will be using a 40A30ma RCD as its isolater.
The CU will have a 32a ring for the sockets and a 6a for the shed lights and garden lights.
Does this sound ok to everyone?
Also for outside lights which will be deck lights and 2 wall lights, will normal 1mm flex be ok, or shall i use SWA.
Thanks for your help, and before you say, get a professional in, I have sat exams for being an electrician, but as im sure you will agree sitting exams and actually getting experience are 2 different things.
Thanks again for any help you provide.
nobody knows exept the op ! i wouldnt export tncs also this depends on the run.
