Has anyone used any low energy, or LED flood lights that give the same effect as a high powered halide, or sports light?Needs to light up front of church, in below photo.
google led flood light.i mounted a 70watt led floodlight equivilant to a 250watt halide.cool white to much in your face.warm/soft light are great and energy efficient.
See various options here - the 20W LED is proving very popular - equivalent to 120W output and very reasonably priced or step up to 50W which is equivalent to 300W:cheesy:
I go for Heathfield LED for all my LED products the floodlights and High bays they do are top quality, they use top quality drivers and chips and the quality is superb, I found them to be alot cheaper than alot of other companies.
i would aalso like to light up a building , was thinking metal halide with red lamps.. the building is 10m high and will be mounted ontop of the shutter cage to the wall going vertical up, slight angle..
there is 2 sets of windows on the building so will require 3 fittings.. cheers i would also like to put these on an easy set timmer
I wouldn't go for coloured lamps in halogen, I would go for either a coloured filter in the fitting or go for a coloured LED flooflight,LED will give you a more direct light which I think is a better solution for your project as the beam angle is smaller
When the prices come down more I'm going to light my house up, but will put a colours filter loop in front with a small motor so that the house changes colour every few seconds - should make the locals take notice
