C
chopper
just after some advice/ideas im putting some cladded eiling up in my kitchen and some downlights, just finding it hard on how many to put in, my kitchens 4meters long and 3 meters wide , so i was going to come 1 meter off each wall and have 2 rows of 3, but im worrie this wont be enough, what do u guys think, i dont want to put 9 in as this will be overcrowded,
the lamps i am putting in are 3w gu10 equal to 50w, how do u guys work it out?
Depends on things like how the kitchen is laid out, Just bear in mind there's normally a joist where you want your downlights so these have to worked round
And if 3M in general I'd come 750MM in from wall, so spacing of 750-1500-750, for 2 lights.
4M long for 3 lights I'd go 667MM in from wall, 1333MM between lights.
The joists will also play a factor though, they could very well be in the way!
I fit 9 led spots in a kitchen not so long back. They had 29 leds in them and where the equivilent to 10w each. Brilliant white. They replaced the halogen ones that where there origanaly. Much brighter, customer was well happy. You can also buy them in soft white. They cost around £4/5 each.
Jay
Glass lamp, in style of halogens
Older chips for the SMD LED, 3528's and not 5050's
No offer (that I noted anyway) of a guarantee. Can get the 5050 SMD led's from ebay with no guarantee for £5-6. LED Hut/CEF other wholesalers give you 2 years on them for £7+. Its not the 7+ years that halers, JCC etc offer, but these don't cost £30+ either.
Are all these gu10 led lamps fire rated? Do they have to be if the downlight is fire rated?
I've seen Philips ones that are plastic and wouldn't last 30 mins in my eyes
Jay
were from jay bargain them
TLC direct. They were on offer at the time but i think they are only £5/6 normal. They actualy only had 21 leds not 29. They are 1.3w but equivelent to 10w. They were bright white. Type in
TLC direct on google or jeeves, click on it when itcomes up, go in to sales & browsing, go to internal lighting, type led lamps in the search bar, click on gu10 leds and they should come up with a choice of different colours.
Jay
I fit 9 on a kitchen ceiling of around 4m x 4m, 3 rows. So they were about 1m apart. And as I said before the leds I used were equiv to 10w and they were alot brighter than the old halogen ones which were in there before. Just put em in and see, if they need extra ones putting in, im sure the customer will tell you and this will give you some extra work, cha ching!!!
Jay
What use is a 10W halogen or equivalent to it? Under cupboards and in cabinets I can understand, but not in ceilings. Gotta say I have never come across anything less than a 20Watt GU10 and even then not seen many of them.
Try this web site for an idea
How Many Lights
If the link is down go to the halers web site and click on the LED H2 downlight. Choose any style and colour and there will be a link saying "how many lights do I need". Play around with the simulator and see what you think.
I put your room dimensions in and changed the light sources wattage to 50 and it came up with 9 lights would give you over 350 lumens. A guide would be 300 lumems for a kitchen.
I read something recently on lighting design for downlighters and it said its more important to light the areas that require functional light rather than space lights out geometrically in the ceiling. Eg dont worry to much about lighting the middle of the kitchen, design the lighting to illuminate the work surface or eating areas.
When doing spots, as a general rule, like D80 said, I make the gap between a light and a wall half the distance of a gap between each light, so for a row of 3 in a 3 metre room you divide the ceiling into 3 spaces and put one light in the MIDDLE of each space, not divide the ceiling into 4 and have the light on each divide line...if you get my drift...this is what amatuers do and it looks crap.
The above method gives completely even light distribution across the room.
I worked in a flat the other day where the landlord had replaced every downlighter lamp with a 1 watt led lamp....and half the flat was uderground. Tight git was charging a flat rate, bills included and wanted to save on bulbs and juice. It was like a bloody cave.
HALER EVOLVLED these ARE equal to 50w halos and are 7 or 8 watts 7 year warranty its the same as most LED stuff just now the cheaper the bettter ( for a week) as one of out clients found having replaced 50 halogens with "LED equivelents" they are having to spend more on lamp replacement AGAIN after 6months ( more than half are out or flickering so bad that people notice and ask about epilepsy as its a high flashing rate) OK they are on 24/7 BUT Halers warranty is 7 years No limit as to lamp usage
The only GU10 leds that give a true 50w of light are the tryco4. i have used them. best on the market. they are 4w, super bright. trouble is they are hard to get hold of. look on e-bay
I'd steer well clear of ebay for LED Lamps. If you want the dogs dangly bits of LED's that match up to 50W halogens - the Haler stuff seems to be the answer. Be prepared to pay for it though. In my neck of the woods no one will pay the money for it though so I can'r speak first hand about them (and I'm too much of a miser to install any in my home either!)
You won't get 50W equivalent from 4Watt Led's. If they did that, then they wouldn't be hard to find and get hold of (unless reliability was an issue!)
The LED Hut SMD stuff is pretty good, but its not a match up for 50W halogens, they run around 4W each, match up to around 35-40W perhaps. The angle of the SMD stuff is pretty helpful in many ways, I find the overlap in lighting helps it. That said its gonna be poor if you only want to light up one area, as the spread of light is so large. About a quarter of the cost to buy.
I swapped 4 x 50w halogens for 4 x 8w Halers leds in my own hallway, and can't tell the difference. If anything, the Halers APPEAR brighter due to the colour temperature (but aren't as far as lumens go). 4 down, 21 to go.....
Although, have just bought some Robus ones for a job, and they come with dimmable drivers as standard and my wholesaler reckons are just as bright as the Halers. Slightly cheaper, too.
Question for D80 and anyone else- Where would I find out more general info on LED lamps. How do you know or compare what are good and bad etc. Do you just look at the wattage compared to the lumen output of the lamp? Whats all this about chips?
Rockinit- I have the Halers in my bathroom and there spot on. We pay just under £30 for these but the Robus version are nearer £40 so I havent bothered so far. With all the competition out there it wont be long till they're down near £20....well hopefully.
Try these - newer chips in them with the SMD 5050, and cheaper! Nice big angle off them, so you kind get away with any poor placing of the downlights! HUGE DISCOUNTS on GU10 LED Bulb 220 Lumens 45W Equiv
I did try these. They actually say they are 320 lumens output, and i fitted 3 today in my kitchen instead of 50watt halogens. I think they are brighter and have a nice wide angle like D80 says. Well impressed. I'm going to buy some more. Only 4 watts! nice recommendation, thanks again.
Leds gu10 spots in my kitchen
chopper,
PB1,
