Was offered work for a kitchen company - £30 per spur/socket, if any upgrades need doing that's in the cost, you take the rough with the smooth! It's no wonder corners are getting cut, the price is low to start with and if you need to upgrade/add bonding, rcd's etc you are well and truely hammered. I declined the work, but someone else didn't.
My math isn't that bad... lol!! your talking 165 quid for a return visit, Tel's talking 120 quid, so 2X 120 = 240 quid!! Testing should form part of your per point price in any case!! Or is the norm to quote 80 quid per point, + testing, + fuel, + return visit, etc,etc?? On your first visit, (if 2 visits are required) your not doing 80 quids worth of work either...
I make it £325 for a two socket 2 visit job. Steep indeed. I charge £500 labour and cable to wire a bathroom which is always two visit but usually around 10 points. The clients are predominantly millionaires too.
I think £80 price for a socket is reasonable enough for small jobs where there may only be 2 but then charging £165 to put a socket on the socket they've just paid for? hmmm?
If it were me I'd only charge travel time and fuel on the second visit (£50-£75) the work you do once you get there is work you would have had to do anyway on a 1 visit job so asking to be paid again for it is going to make you look like a **** taker and could even lose you the work
i am far from cheap, yet i feel you are very expensive , good for you if you are getting it though
Not so much i'm trying to be expensive, its just the work can be 40miles away plus and i can spend half the day getting there sometimes in which i'm trying to not do myself over! I don't rip people off i have plenty enough work at the moment and do not really need to scrimp myself just to make a couple quid.
fair point, by all means charge the maximum you can get away with but I'd suggest the second visit call out should be variable depending on time it takes to get there...£15 per quater hour spent driving or summin...
Yeah i have put forward £95 as you are correct in that it shouldn't take long to fit faceplates and lighting fittings. and if any remedial works are required then they should be found on the first visit and then arranged for 2nd visit at extra cost. So i think £95 would cover time and travel if far out of town, being fair to both parties.
