Rule of thumb is if it's old with a Type number it's a 3871 if it's newer with a Type letter it's a 60898.
e.g. Type 1 and 2 = 3871 , Type B, C, D = 60898.
Also if it's rated at 5A, 15A or 30A it's generally a 3871 as the newer 60898s are rated at 6A, 16A or 32A. No idea why they upped the rating slightly on the newer breakers though.
Which ever they are, they want binning ASAP. They are magnetic/hydraulic where as modern breakers are thermo/magnetic. Not very sensitive to prolonged low-level overload.
They look like the DS breakers, based on the USA design. They were out and out crap when they were first introduced and are still crap today!! They don't give a very close protection, better than a rewireable fuse but not that much better!! lol!! The old C50 breakers are not much different either!! These CU's and the breakers need binning whenever possible and replacing with up to date equipement!!
The reason for the 6/ 16/ 32A etc values over the old 5/ 15/ 30A etc values, is purely for our old friend ''harmonisation''...
they are Dorman LM and as E54 says they should be BINNED i have in the past argued that "live exposed parts" only to have " by use of tool " throw that argument out these dbs are downright dangerous and IMHO should be replaced ASAP that argument aside they do comply but Zs are guff and this gives reason for replacement more that acctual physical construction
The Zs is high because they are type 3 or 4, totally unsuitable for domestic use in most circumstances!! Add to this a course sensitivity compared with the more modern MCB's and you have even more reason to get shot of them!! lol!!
