K
Knobhead
I could be rotten and add a duff N/E in to the mix
I have been having a quite night but after trying to get my mind round this I think it's time to reach for a bottle.
The way I understood this phenomenon was simple physics:
A is a measure of the number of electrons passing a point per second.
V is the potential difference so the force pushing the electrons along.
In plumbing speak the A is the volume of water and V is the pressure or head.
In a circuit the electrons will take the easiest route to ground. The electrons are all being squeezed through a small section of copper and therefore encounter resistance - V=I R. The back up due to resistance is the V measured between E and N. It is 0 at the consumer unit as this is near where E and N are merged tnc (not tt) so there is no relief of V by shorting N and E.
This leaves vd. Is this not caused by the resistance in the cable v=ir. E.g. If 10a of current flows through cable with 1 ohm of resistance the vd is 10v?
I am now going to pour a stiff one. Would be grateful for some clarity on this.
Physics????
A lot of mumbo Jumbo if you ask me!!!!!!
Iv'e never seen any electrons or even been shown any at the college.
Its not electrons, its positrons that flow when a current flows.
Thats marvellous, but I still don't quite understand!!!!
Physics????
You are a magician!!!!
The OP does not tell us the 242V figure.
Where did you get it from????????
You sure that's r8????
Physics????
Iv'e never seen any electrons or even been shown any at the college. You need stronger spectacles.
And there was I, believing my old lecturer when he taught us it was all about electron-hole-pair movement....
