Hi all, my first post too, i do have an editable EIC, i have exported as a pdf, but the original was made in openoffice and this site doesnt allow the uploading of .odt files :(
i can have them in other colours, and also the "domestic" variant of it too
Mark just to add that although your files say that you can only print a copy instead of saving there is a way to do it with Mypdfconvertor
this little freeware acts like a virtual printer lets you save as a pdf but at the same time your documents think it printing it.
hi Mark
is there any way that you can adjust it to drag and paste info into multiple boxes at the same time to save time filling in repetitive details like on test sheets etc
thanks and good work!
hi Mark
I have NO IDEA if that can be done, it is a basic PDF document to me.
I could probably add a drop down box in the Ins Resistance tests as there is a bit of room, but not much else.
If you want to 'save' the pdf's so that they can't be edited when emailed to customer, then add this in - it bascially installs as a printer, so you can now print anything to a pdf , inculding an existing pdf, vopila, a now 'fixed' document, with the form filled in.
I save them with the certificate number in the file name
http://www.tracker-software.com/PDFX4SA_LE_H.zip
That's Version 4 Lite of PDF Xchange Viewer- it works as a printer deiver so just appears as any other printer does, other versions tie you in to trialling / buying the pro version. So check out the main site, make sure you use the above link though to get version 4 lite.
If you are an Ipad user look at the NICIEC app. Forms nice and easy once finished email to yourself and client. Hopefully all the other companies will look at this at bring out there own versions with correct branding on etc. Things can only get better
does anyone realise that the regulation some of the numbers on the inspection schedule are wrong
on schedule of inspections 3.1 should be (542.1.2.1;542.1.2.2) 3.2 should be (542.1.2.3) 3.5 should be (543.3.2) 3.7 should be (543.3.2;544.1.2) 3.8 should be (543.3.2) 4.8 should be (612.13.2) 4.14 should be (421.1.3) 4.17 should be (521.5.1) 5.2 should be (522.8.5) 5.5 should be(section 523) 5.10 should be (522.6.101) 5.11 should be (522.6.101;522.6.103) 5.12 bullet point should be (522.6.102;522.6.103)
Bleedin hell, okay, leave it with me and I will update it, to be fair to TesterSteve when he created these he did it before the printed book was out, I only update them as and when necessary I don't use them myself!
Tester Steve,
mydigitalhome,
