I've not seen any of the rockers go yellow though, to be honest. I like the Crabtree stuff.
I'm looking at some 'yellowed' rockers now in my gaff, might have something to do with me smokes though! I imagine they must be made of different material to the rest of the accessory though, as its only the rockers affected!
I still think its the best of the bunch and seems to be the standard accessory range used by most round our way, decent prices, decent quality, decent standard looks etc.
A few years ago I had the idea for a invention for car engines, when you first switched on a electric pump would prime the oil ways with oil as a oil brand was claiming most engine wear happens just after first start up while oil pressure is building up. At the time the engine was lasting longer than the body work on cars anyway.
Lol my Dad did that first , it was called a starting handle , he always cranked it from cold before using the electric starter.
Keep thinking fella,its nice to see a bit of inventing goin on. Some ideas, although very useful,never convert to wide use or income....keep at it,everybody laughed at my cordless-generator and solar powered sunbed......Good luck.
According to wiki, the UAE, Singapore and Indonesia use ring final circuits.
Hell of a lot more countries use the British ring main than you have mentioned above. And that's not including the majority of prestige buildings in Saudi and the Middle East as a whole!!
here in ireland n our latest regs ring circuits are not allowed in kitchens anymore and two radials must be provided
So what's the dumb reason behind that little cracker then??
It’s the new reg’s, what’s reason or logic got to do with it!
I’ve got to admit that one defies logic!
God knows ,id say its because more things can go wrong with a ring final cct compared to a radial
Like what?? These would both be new circuits supposedly installed to the current Regs/codes by, one would hope competent electricians!!!
More like Ireland has the same problem as the UK, to many fast track wanna-be electricians that aren't competent in testing or fault finding anything except on single length's of cable...
If an open circuit occured on the ring and is unnoticed then effectively it is two radial on a 32 amp mcb wired in 2.5
or
mr. d.i.y. could mix up ends into different mcbs (even though d.i.y.ers shouldn't attempt this sort of thing)
All sparks here have to do a 4 year apprenticeship
or
What's Mr DIY got to do with anything, you can't base electrical Regulations on what they might or might not do...
As i've stated in other threads, there are pro's and con's for every type of circuit!! Designed and installed correctly there shouldn't be any problems with either type of circuit....
This old chestnut of a ring becoming open circuit, in all the years i've been in this industry i've never come across such a scenario.
Now that is good to hear, about the 4 year apprenticeship... Just keep your fingers and toes crossed that it remains that way, and that the powers that be in Ireland, don't allow your standards to fall, allowing the leeches and these fast track training centres in through the back door... lol!!!
KevinS,
Brightspark2,
