- Reaction score
- 1
Nice job for a first attempt, why didn't you put a vertical run in to collect the cables between the 2 enclosures? less drilling than all the cleats!. As above I would have used shallow (20mm) unistrut bars to mount it on.
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
Good install but should the tails not have been changed
A Db I never got to finish
Ahhhh building company went down the pan and all trades booted off site, that was back in June and were still not sure if we're going back, it was a pig of a job but I would have loved to have finished it.How come?
View attachment 15566Here's one of ours
16amp was used for fire and six for used for heating. Working with a local authority so they keep an eye on spare rcbos making sure they are not swapped for blanks
earth 11 was earth to gas which was getting took out when I wired the new 10 mm to gas that day
fitted a small consumer unit today for audio equipment
is the consumer unit in a unfinished building? Looks like you can see the sky in picture 2 as if there's no rooffitted a small consumer unit today for audio equipment
Nice board, looks like a small supply for such a big board ?
Our local wholesaler are modeller stockists so that's why I always buy it. Where are you in the country ?
whats the deal with the RCBO earth connections in the DB? never seen that before, but don't work on domestic.. i was always told that RCBO earths have to go into the same connection as the CPC for identification, surely the RCBO earths need to be numbered?
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
