Tipex the 13amp out and write 8 in a fine permanent marker, i find this the best all round solution and you cover your back then ;)
That Tipex is dodgy stuff.
Last time I used it the fumes from it went up my nose & made me feel a little queer.
Errrrm! Tipex is mild.... next time try the permanant marker but try avoid touching your nose with the tip as its a tell tale sign of your experimentation ...Damn you detentions; took me yrs to figure out how they knew!
theres fuses in the side bit of my box if anybody wants....
- - - Updated - - -
Geordie Spark,
grantr37,
