Wonder if its a three phase supply? Fault on one phase and turning the ring on that don't work is allowing power to flow through that and back feed to the board?
It's just a thought, I'm hoping tony or en54 follow it a but further as their they guys for this, no offence to anyone else.
i'll nip over in the gulfstream later. a £7500 call-out is about the going rate for switzerland these days.
Hi everyone,
I hope someone can shed some light on this. I tripped the lights in 1 half of the flat today when installing a ceiling light. When I'd put it back to how it was before I flicked the main power switch back on but no power. A little later my wife tried to use the oven (which is on a different trip switch), the oven doesn't work now, 3 (I think?) rings on the hob work, while the other one doesn't work but when you switch it on all of the power comes back on in the flat. When you turn it off so does all the power in the flat. Any ideas? I hope that makes sense...
So it all worked fine before you added the lights to the lighting circuit/s? and then you put it back to exactly what it was before you started?
There are two possibilities here:
1/ It is something that you have done
2/ It is something that was done by the electrical contractor and you have now highlighted the problem
What's anyone else think about this?
Sounds very plausible, was thinking the same thing. I think it's quite common on the continent to have domestic hobs and ovens on multiple phases. Wouldn't surprise me in Switzerland if they insist every house has 3 phases and keeps the load balanced to within 10%.
After all, this is the country where you get fined for mowing your lawn on a Sunday! :41:
Sectionq - you need to invest in a visit from an electrician, preferrably while you still have a flat for him to visit...
Spark turned up this morning, took one look, went outside to the main box, reset it, came back in switched our power on and it's all back to normal. And yes, it is a 3 phase supply, I don't know what that means but a tip of the hat goes to electric will! Thanks for all your replies everyone, all back to normal, it's lovely having electricity again!
