A
allybally
I'm just wondering, Is this 10 amps per switch or overall, or per switch, I've got a 2 gang switch thanks
so you have 3 kw on a 10 amp switch then? oh dear :bulb2: what size cable and circuit breaker is on the circuit? what type breaker? and how did you calculate your load?
Long as your switch is protected by a 10 amp MCB or lower you should be fine.
