N
nocturnal
Hello,
I am wanting to install a double socket near the consumer unit (ref. photo)
Should I tap into the mains ring OR tap into the existing junction box as shown (says 'W/Machine Dish Washer Light on it)?
Obviously I'd need a fused spur unit if I am attaching to the existing junction box.
I didn't do any of this previous work, an electrician did.
Cheers
split the tails. wire the feed to w/m and d/w from a new sub board with RCD protection. then add your local socket
sorry... w/m d/w?
so a new RCD board?
I quoted £50 for doing this (mainly as a favour) but £50 won't cover the materials for this method!
Can I not just take a spur from the ring mains using another junction box?
Add a spur from the socket circuit on the existing board, surface cabling and a RCD socket. Job done.
PS That assumes the bonding is in place - if you know what that means!!
sorry... w/m d/w?
so a new RCD board?
So basically you're trying to be an electrician whilst clearly not having the first clue about what you are doing!! Jog. On.
Yeah £40-50 for an RCD socket, which will be the cheapest method. You won't be making much out of this job though if you've quoted £50.
:rofl: unlucky..................go on tell us what you trade as................landscape gardener?
Nothing to do with you I know, but does the shower unit/circuit have any over current protective device?
Is there a spare way where it's marked shower I can't see that we'll on photo as there is a an rcd there
Is it a two way enclosure?
