What wholesalers have wago/line products on the shelf? I have a similar job myself coming up
order from line products and the gear will be delivered within 48 hours.
That reminds me Tel', I've been meaning to thank Line. I received an order from them 'next day'. Nothing unusual for most of you guys in England, but when your up in Scottie-land you normally get treated like a 3rd class citizen!
So official 'Thanks' to LIne for the order :)
You can also use bare CU cases for a reasonable price. I've done two this way but used a matching case to the new CU that was being fitted so that it looked neat. I'm guessing cost will be the main factor on this job though, so you can find a supplier of cases at very reasonable prices like this for example MK Sentry Insulated 12 Way Consumer Unit K5686s #L74 | eBay
Drill two neat holes in the cover to screw it closed and it's as secure as an adaptable box. Added benefits are that you can label the connections as you would the circuits, and you can use the earth bar.
Hmm that's interesting. But I wouldn't want someone thinking they needed to get into it and trying to prise it open with a crowbar..
Along with the usual (warning 230v, wiring in two colours, risk of death, risk of society collapsing etc etc) I put a sticker on the front describing what it is "This Junction box contains connections, and should only be opened by suitably qualified persons. The Consumer Unit is located xxxxxxxxxx" With that and the two clearly visible screw heads I feel it's adequately protected/described. More so than an adaptable box in some respects.
In traditional form of recommendations you could also connect an emergency light at your joint box, handy if it's going to be above your CU and the clients are elderly :)
kingeri,
LineProducts,
