What wholesalers have wago/line products on the shelf? I have a similar job myself coming up
order from line products and the gear will be delivered within 48 hours.
That reminds me Tel', I've been meaning to thank Line. I received an order from them 'next day'. Nothing unusual for most of you guys in England, but when your up in Scottie-land you normally get treated like a 3rd class citizen!order from line products and the gear will be delivered within 48 hours.
You can also use bare CU cases for a reasonable price. I've done two this way but used a matching case to the new CU that was being fitted so that it looked neat. I'm guessing cost will be the main factor on this job though, so you can find a supplier of cases at very reasonable prices like this for example MK Sentry Insulated 12 Way Consumer Unit K5686s #L74 | eBay
Drill two neat holes in the cover to screw it closed and it's as secure as an adaptable box. Added benefits are that you can label the connections as you would the circuits, and you can use the earth bar.
Hmm that's interesting. But I wouldn't want someone thinking they needed to get into it and trying to prise it open with a crowbar..
If you are after din rail connectors you are unlikely to find a decent selection on the shelf.What wholesalers have wago/line products on the shelf? I have a similar job myself coming up
