well....you wouldn`t would you hawk....lol..I hate those things ^^^
Darkwood I agree. I see "sparks" with the poorest of tool boxes/bags and don't know how the get anything done. I have a very large collection of tools in my toolbag and other tools I don't use everyday stay in the van until needed. Simple as that
used to use bottles daily high.....1/8th nozzle on 1" plate....and i had it down to a tee n all.....just used to click edge of`t plate with a grinder....all that fluff just dropped off......I'm the same mate, although I do also have a load of stuff I carry and never use!
For me conduit cutter every time, quicker, cleaner, neater!!!. No contest!.
And yes I can use a hacksaw, I can even cut round holes in 3/4 plate with a gas axe, I use em out of choice, I believe a tool for every job and the right tool should be used! It frustrates me when I see a spark or any tradesman arrive on site with a chipped screwdriver and bent hacksaw and set to work!.
Not that I'm suggesting any of those that are anti conduit cutters are the same it's just one of my observations that frustrates me!
plastic conduit cutters were a solution for a problem that never existed well unless your incapable of cutting straight in the first place
well i worked in fabrications for 15 years...as a plater/welder....so you get used to using the bottles and plasmas n stuff....we were using oxygen acetylene.....some places use propane....its better for heating is that....with a `pepperpot nozzle`.....if using a heating (pepperpot) nozzle with acetylene you`v got to change the mixer....acetylene`s a `wet gas` see.....it dont like itYea theres something really therapeutic about firing up the actelyne sisters! Took me a lot of practice to be handy with em and to be honest I couldn't fre hand a perfect circle, I used to use a welding rod as a centre pin and clamp it to the stem of the torch with the fingers on my left hand.
take the chill out of it with a heatgun....even a hairdryer would do for this.....At very low temperatures the conduit won't bend either.
You'll be able to cut it with a conduit cutter without it shattering as well.take the chill out of it with a heatgun....even a hairdryer would do for this.....
