A
Adam W
It depends how you cut it.Not really, your more likely to squash the cut ends at the same time!! lol!!
a spin round the tube before you squeeze sorts thisYou'll be able to cut it with a conduit cutter without it shattering as well.
Only the cheapest of plastic conduit shatters.
Nobody said you were. E54 said if the tube is cold it'll shatter if you try to cut it with a bladed cutter. I suggested you could warm it up to cut it the same way you would warm it up to bend it, meaning it won't shatter when you cut it.I was talking about cutting not bending
A good hand job does the trick before a bend. Never seen anyone resort to hair dryers etc..
Junior Hacksaw.... plastic conduit cutters were a solution for a problem that never existed well unless your incapable of cutting straight in the first place :wink_smile:
Moving on is difficult for some people, pipe cutters are fast clean and pricise, a hacksaw is slow messy and hanging off a ladder not very precise, but then again some people think fire is the work of demons
Pict
In all seriousness in a attempt to over engineer a problem that's no big deal, I constructed a coffin out of 1/2 birch ply, it's 10" across, 10" deep and 2.4m long. One end is open , the other is open with a 45• slope top to bottom.
In the sloped end I put a 2kw fan heater on its lowest setting and the other end I can shove a whole pack of PVC conduit into it.
It's a pain to store and I only ever use it on bigger conduit jobs. But it does mean when we are putting up tube, we have a readily available feed of pre warmed PVC ready to cut and ready to bend.
