C
Chris Milne
Ive just started a rewrite on a large grade A listed building and the client wants to reuse the switches as a period feature but I'm not sure! The switches are the toggle type with a brass face plate that goes over the switches and is held in place with lock rings. The back boxes are cast. Basically if you unscrew the lock rings you can take the plate off and the live terminals are open. Any comments would be appreciated.
In the library!! lol
You can get modern standard kit which looks retro mate, it should keep the planning officers happy. I'd be wary of using the old kit.
How old are we talking about here?
Earthing the plates and back boxes isnt an issue, I'm more worried that you can access live terminals without the use of a tool. Probably fitted in the 60's??
i'd say the problem is the exposed terminals if you remove the cover. if a tool is required to remove it, you may be OK. if it can be removed by hand, then it's a no-no, then there's the point of whether you can securely earth the exposed metallic parts.
Cheers, that was my thinking. Anybody know who makes some nice retro toggle switches?
google period switches. but make sure you ( and therefore the client ) has deep pockets.
