Discuss Reuse old switches in the UK Electrical Forum area at ElectriciansForums.net
C
Chris Milne
Ive just started a rewrite on a large grade A listed building and the client wants to reuse the switches as a period feature but I'm not sure! The switches are the toggle type with a brass face plate that goes over the switches and is held in place with lock rings. The back boxes are cast. Basically if you unscrew the lock rings you can take the plate off and the live terminals are open. Any comments would be appreciated.
In the library!! lol
You can get modern standard kit which looks retro mate, it should keep the planning officers happy. I'd be wary of using the old kit.
How old are we talking about here?
Earthing the plates and back boxes isnt an issue, I'm more worried that you can access live terminals without the use of a tool. Probably fitted in the 60's??
i'd say the problem is the exposed terminals if you remove the cover. if a tool is required to remove it, you may be OK. if it can be removed by hand, then it's a no-no, then there's the point of whether you can securely earth the exposed metallic parts.
google period switches. but make sure you ( and therefore the client ) has deep pockets.
Reply to Reuse old switches in the UK Electrical Forum area at ElectriciansForums.net
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi All, I am new to the site and have recently started doing more and more electrical work in my house, nothing too major, changing face plates...
17K
Squid
S
A
Hi guys I’m new to this site however just thought I’d give my best explanation of what the AM2 was like. If this is in the wrong forum I’m very...
12K
G
Doing an CR on a very old period property with some very expensive original features. It has been rewired around 10 years ago but they have reused...
6K
Fin170
F
