B
BobbyNoMates
Ok folks
As some might know from my previous thread, I have been enquiring about fitting a seperate 63a 30ma RCD with its own enclosure in the loft between the 40a consumer unit fuse and the 45a DP pull switch.
All I wanted to know was if I had the right one and if it was appropriate to install it in the loft, as there is limited room near the consumer unit.
However, after the response I got, still non the wiser really...and I know it should really be done by a qualified person, but at least I am trying to make sure it is done correctly.
Anyway, my question is,..What would a reasonable price be for an electrician to swap my main consumer unit, for one with an RCD? ,as this would be another option. My consumer unit is only small, an has 4 fuses in it, 6a, 16a, 32a and 40a
cheers everyone.
Depends on whether Bonding is up to scratch, that may be needed as well, 350-500 at a guess, my experience with these 4 way boards is that 6 or 7 circuits are in them doubled up on the fuses, you may be suprised.
Agreed with Mike.
I'd be going in at £350 min, then other variables that can only be determined during a visit, may well further increase the cost.
A small price to pay, for permanent peace of mind.
*Don't forget to add £1.99 to the job cost for a good biscuit supply either.
bobby, there are a few members in your area, i'm sure would do you a fair priced job. either a new CU or a separate dedicated RCD/MCB unit for the shower. 63A/30mA with a 40A MCB. i did exactly that yesterday and charged £90. took me 1 hour.
he went to a good school. it was approved.
Thanks, that seems reasonable, although I'm pretty sure mine would'nt turn out to be a straight forward one!
If the photo has managed to attach to this thread, you can see the space is limited around the CU, but given that the CU would be overloaded if everything was on at once, a new main CU or dedicated shower RCD/MCB CU at least
Why can't I ever think of good phrases like that to say
Yea sorry pal thats copyrighted, should you want to purchase any of my quotes, phrases of metaphors, a bespoke booklet can be made up for you or you can simply purchase one off sentences at a small fee of £25 per item + VAT + entrepreneurial tax + originators fee + a contribution to my artistic license (see what i did there) + creativity allowance: GRAND TOTAL:- £678.96
Then you'll become to most well spoken and interesting man down the pub...and customers will think your funny and trustworthy
Since when have you ever seen a domestic CU loaded up, by everything being on at once, with every protective devise ready to trip on overload.... Let me guess, ...NEVER!! lol!!
Ok folks
cheers everyone.
Bobby...further to a thread that you featured on so prominantly yesterday evening....i would suggest you understand the difference between earthing and bonding before checking that an electrician is...`doing the job correctly`...lol..
Hi,
Looks to be eight cables in the vicinity of your CU ( not including tails ), so as previously posted; there may well be more than four circuits in there,
Regards.
Hi,
Regards.
There is an addition cable that you can't really see coming out the left...this one is a live and just terminates into a junction box. The cable on the right, goes to a 2 way light switch. It was like that when we moved in over 10 years ago...apart from the shower cable. I may have to make more room around the CU and have an updated RCD protected one fitted...this seems to be my best option, or maybe make room for a separate dedicated shower RCD and MCB unit.
cheers
cant you remove the cupboard its fitted in to allow more room for the new one ?
otherwise you may be in for a hefty bill as you will need RCBO's to fit a small enough board in that cupboard :)
Ha, ha...but the electrician I had to my house last time obviously didn't seem to know much about earthing...connecting it to fresh air and all that! Well, he probably just wanted an early finish! Anyway, I do know the difference...just not the correct terminology...honest! But I am certainly not an electrician and will only carry out what I fully understand.
cheers GlennsparkGlennspark
BobbyNoMates,
GLENNSPARK,
