B
BobbyNoMates
Ok folks
As some might know from my previous thread, I have been enquiring about fitting a seperate 63a 30ma RCD with its own enclosure in the loft between the 40a consumer unit fuse and the 45a DP pull switch.
All I wanted to know was if I had the right one and if it was appropriate to install it in the loft, as there is limited room near the consumer unit.
However, after the response I got, still non the wiser really...and I know it should really be done by a qualified person, but at least I am trying to make sure it is done correctly.
Anyway, my question is,..What would a reasonable price be for an electrician to swap my main consumer unit, for one with an RCD? ,as this would be another option. My consumer unit is only small, an has 4 fuses in it, 6a, 16a, 32a and 40a
cheers everyone.
cheers everyone.
