C
chloebear
Hi All,
Customer has very neatly managed to put a 4" nail into a plastered wall right through the cable feeding socket below - "it went bang" , did it!!!!!!! how strange - so what would be the best way of effecting a sutible repair to the cable without trashing too much of his newley decorated wall??????????
depends, not really enough info to give an answer, dig out the cable. try refeeding without damaging the wall possibly other side of the wall not decorated maybe pop threw from other side. is there a void above in the ceiling if its a ring are both cables damaged? possible to do a junction at top and wire as spur?
Not long before someone will come up with the old 'crimp and heatshrink' solution...dont...it's a bodge...and whats more a potentially dangerous bodge.....You know the correct way to sort this,there are no quick fixes.
I agree with Murdoch, Put another socket further up or down depending on the way the cables run.. As for making a mess then im sure you can agree that if there going to put nails through cables then what do they expect..
Saying all this I recall repairing one like this before.. However after following the cable it was fed Diagnally so that opened a can of worms
This is assuming both cabes on the ring are fed the same way..
Looks like I need to rub my hands together and get ready to make a mess - oh well, could be worse, could have been my wall!!!!!!!!!:tt1:
if the cables come down to the socket, the least messy fix would be to get the floor above up, find which of the 2 cables is damaged, then joint the undamaged cable under the floor so that the affected socket is then a spur.
^^^ Exactly what he said if both cables come from same direction you can effectively pull a few boards up or get in loft space etc and change it into a spur...... absolutely no damage to deco' except the hole the original nail went through...... then a lesson to customer about zoning!!!
Here it comes......
A year or so ago I would have totally agreed with you, but if the joint is good and the heat-shrink watertight, why should it be dangerous and not last the lifetime of the installation?
I'd smash a hole in the wall, joint the cable using a screw terminal junction box. Re-plaster hole and jobs a good-en'. Forget certificating the work, take cash (having overpriced the work) and on to the next job :)
junction box? too expensive. choc block and a bit of tape. then fill over.
mmmmmm, i though just twist the ends together, bit of tape and fill with polyfilla - any good???????
Hi All,
plasterboard wall you say eh....so will the damaged cable pull?...if so tie a new on and use the old to pull the new in
