N
Newbie90
Hey everyone,
I have recently qualified as an Electrician but have very minimal domestic experience so I apologise in advance for my ignorance.
I am looking at replacing a consumer unit for a relative and the council will test afterwards as I am not NICEIC registered.
The property is a 1 bedroom apartment/flat.
The incoming supply from the meter is 16mm live and neutral with a 6mm earth. The main fuse is 60A. I will be upgrading the bonding to the gas and water to 10mm.
The query I have is that I believe the incoming earth cable should be be at least 10mm as the supply is 16mm (I may be wrong) :)
Its a nightmare to put new tails in as its a flat but do I need to upgrade the main earthing conductor? If so, would ut be 10mm?
Any help would be much appreciated.
As Jay says there is adibiatic equation in order to calculate the size of the main earth..
I can work out the equation but dont have access to the property at the moment.
I know that using the equation always works out a lot less than you would first think.
All i need to know really is can I have 16mm tails, 10mm main earth and 10mm bonding?
Ehhhh, You have all the information. Why do you need access to the property..
Well we could give you the answer, but I suggest you look in the regs book, tell us your thoughts then we can either agree or correct you, have you got an OSG by any chance? see I don't like sparks without either a regs book of their own or at least access to one, can you see our point fella, congrats on coming out of your time by the way, good man, pleased for you.
Mike
Don't think that we're having a go at you over this mate because that's not the case. Have a pop at the adiabatic and post up your result, I'll bet you'll get a load of answers then even if you're wrong.
When I get home I will have an attempt.
I have a regs book and OSG.
Off the top of my head I believe I need the Zs reading though don't I?
Have a butchers at you OSG when you get in mate, I think you may be surprised how easy it is to work out..
Will work it out tonight or tomorro ad post answer. Thanks everyone
