N
Newbie90
Hi all,
Been trying to work out the earthing conductor size using the adiabiatic equation for over an hour and totally lost myself. (Wouldn't think I got a GCSE A for maths) lol
The OSG without calculation shows that the minimum earthing conductor is 16mm with 10mm for protective bonding.
However, I have seen an example equation on the tlc website which is almost identical and it works out that 6mm is sufficient as the earthing conductor.
I believe that 10mm for earthing conductor and 10mm for protective bonding is suitable.
Does anyone have any useful guides for learning and working out the equation?
Also, does anyone agree that 10mm is sufficient for earthing conductor and bonding (even if the main fuse was 100a)?
