K
KevinS
Hi,
ive been tasked with writing a 'standard operation sheet' for plumbers to replace electric showers safely.
at the moment they are replacing showers with no test gear, then the electrician is following behind doing a Zs
my concern is; they turn it off at the dp switch and remove the shower, I am not happy that it is dead when they turn if off as they have no method of checking. There may be a fault on the dp switch and they would not know
is this an acceptable procedure
remove cover of shower.
turn shower on by double pole switch,
VOLTSTICK (yes I know) will indicate,
if volt stick does NOT indicate, stop and wait for advice off an electrician
turn off by dp switch, VOLTSTICK will stop indicating,
if VOLTSTICK does not stop indicating, stop and wait for electrician
switch breaker off at board and proceed
i know what you are going to say, but the company won't pay for test gear for 20+ plumbers, hence the VOLTSTICK idea.
is this classed as safe enough, it's safer than what's happening now,
cheers
Testing for dead with a volt stick ? I did that once. I do miss those side cutters.
Anything you sign your name to has got to refer to proper safe isolation procedure and be carried out with proper approved testers. Anything less and your arse is hanging out in the breeze imho.
May be better checking for a pulse....after isolation, of course.
Why doesn't the electrician go too when plumbers turn up to change the shower he/she can isolate for them correctly then revisit to do the test. Simples
Well it's that 15mm water pipe innit ..... can't have electricians touching that mate .. that's the plumber's job!!
That will be because you don't understand the different compression (or sealing) properties between a copper olive and a brass olive. Is the brass olive one belt with the apprentices head against the end of the spanner to seal and the copper olive two belts with the apprentices head against the end of the spanner to seal?
Or the other way round?
See the issue?? Its highly technical and you need to be able to read grunt to be able to understand the plumbers regs. (and find a copy!!).
(Just realised I'm quoting Geordie who, may, have a subliminal understanding of grunt!! :smilielol5::icon10:)
o oh.....flush the toilet and the light comes on.....
I'm not letting a plumber anywhere near my new TechnoToilet!
And who are you calling a grunt????
To Serious a note here, This is under Bad Practice for whoever is involved.
The Electrician Should Isolate the Shower From the DB or CU meaning remove cable from the Fuse, before the plumber gets his nutty hands on it, its all stated in the Regs, Isolate, a volt pen is a no no a Proper Volt tester (multimeter etc) should always be used, bugger me what kind of forum is this..... next Lick it to test that works..
I would remind your employer that company directors have responsibilities as well. If they think they are pulling a flanker by pushing the responsibility onto you, they are sadly mistaken.
correct having an un qualified person work on the equipment with out proper equipment is plainly stupid
our guys at work all have these kits
Breaker Lockout Sampler Pouch With Brady Safety Padlocks & Tags - 99296 - BRADY
there is also larger kits with the large plug isolators for 3 phase plugs like the nema 14-60p (shown here)
NEMA Plug & Receptacle Configurations Reference Chart (Straight Blade)
to the op do not sign off on this (those weasels are just trying to avoid responsibility)
H
hotwaterproblems
H
Plumbers replacing electric showers
KevinS,
gnuuser,
